Changed the oil today and noticed tiny particles in the drain pan....
These look like very small bits of gold glitter...if you rub them between your fingers they can't be felt as they are so small. The bike has only done 19000.
Can't remember seeing this before...should I be worried?
) and the first two times there was metal bits. I'm now a few oil changes and >15,000 miles further down the road and there has been no metal since.
It was then I remembered that I had chucked some other waste white spirit / oil etc that I had kicking around in various containers . So I dug around the bin and YESSS> found the culprit container with remnants of swarf / oil from using it as drilling lube........
