hi there.wondering if taking off black front engine cover so i can paint over corrosion underneath ,would i need gaskets or oil drained or is it simply on and off no worries cheers zippyonyack
If you bought it new, take it back to the dealer and discuss the possibility of BMW standing some (or all ) of the cost, as this is a known fault. Same happened to me and it was replaced as a 'goodwill' gesture on my '05 bike. Good luck.
Its a fairly involved process as you have to drain the oil and remove the lower alternator drive belt pully which needs the inevitable special tool. The haynes manual explains it fairly clearly. When mine got done under warranty it took the work shop about 4 hours.
