guitarman
Just bled the brakes on the 1150 after 3 years and 18000 miles (oops slapped wrist
). Front was no problem but even though I'm sure I've got all the air out of the rear the pedal still appears to be moving over it's full travel (if you see what I mean) and doesn't appear to be having much effect on the braking.
It's almost as if there's a leak somewhere although I can't find any fluid leaking out and the reservoir level isn't moving.
I will say that there has always been a fair amount of travel in the lever and it's never really been that effective anyway.
Any ideas?
Dick
). Front was no problem but even though I'm sure I've got all the air out of the rear the pedal still appears to be moving over it's full travel (if you see what I mean) and doesn't appear to be having much effect on the braking. It's almost as if there's a leak somewhere although I can't find any fluid leaking out and the reservoir level isn't moving.
Any ideas?
Dick
