Malcolm Leick
Okay, I thought I knew what I was doing, but now I'm not sure.
I replaced the top section of the brake line on my 650GS twin this morning. So the new top section is of course full of air. I left the brake reservoir in a position where it wouldn't drain. Then having fitted the new brake line, I started bleeding the system.
I was expecting the brake fluid still left in the lower section of line (which I hadn't removed or drained) to come out first, followed by the air from the top line. I've now put about 350ml of new fluid into the reservoir (4 refills) but I'm still getting fluid coming out of the bottom. No air so far. Am I doing something wrong, or do I just keep pumping? I also checked the nipple next to the brake reservoir but I'm getting fluid from there too.
Where has the air gone!!!!??? I know air rises, but I am presuming it will be pushed through by the fluid coming from the reservoir.
