Bleeding brakes on K1100RS
Kenny
Trustworthy Scouser AND
Moderator
Moderator
Toxteth scouser, made good ..now hiding on Wirral
I know I should buy a manual....but bleeding the brakes ( especially the vague front lever )...is it a 'traditional' bleed or
are there 'hidden' nipples, procedures etc., I should know about ?
On the ABS Unit you will see two Bleed Nipples
VR and HR cast on the casing My prefered way of Flushing the brakes on these is to
1) check the wee pin hole at the Master Cylinder is clear
2 Flush from Master Cylinder to Appropriate nipple
VR is VorderRad or front wheel and HR is HinterRad or Rear Wheel
Flush through to each until you get clean fluid and then move to the appropriate calipers
You may find they have the damned awful Fill Point nipples on the right front and the rear Just heat the nipple itself and remove with a 12mm Spanner and throw them in the bin and fit New Std Bleed Nipples
The Fluid lines from each Master Cylinder to the caliper are one circuit
(No split circuits servo nastiness to deal with!!!)
If you changed the pads these do have a tendency to be soft till they bed in
