mylovelyhorse
Is there some special trick to bleeding the brake fluid on a 2012 F800GS with ABS? I have one of those vacuum things and I have run about 500ml of fresh fluid through the braking system but I cannot get the air out. I can't tell how much air is in because the nozzle of the vacuum thing doesn't quite fit on the brake nipple and some of the brake fluid is kindly leaking out round the base of the nipple anyway. I can tell it must be quite a lot as I can rather easily pull the lever back to the bar...
