Hi Ash700
Just to clarify, and elaborate on AndrewA's response. The easiest way would be to disconnect your ezCAN to test whether the high beam LED on the dash is giving you feedback as expected. The problem with this however, with the ezCAN disconnected, most drivers won't know you're on high beam as the stock one is horrifically bad.
Furthermore, with the lights reacting as expected to the high beam, that means the CAN bus signal is coming through, i.e. the high beam switch is working as expected. This then only leaves the actual LED on the dash as a possible failure point.
Although others have mentioned the switchgear as a possible problem, I would argue that the switches themselves are working, as the ezCAN is detecting high beam and activating the "see 3 days into the future mode". A good clean is always welcome, but I highly doubt this will resolve the issue.
For some understanding on the ezCAN itself, allow me to explain the influence of the ezCAN. The ezCAN is a listening device, that joins into the CAN bus network using a connection points where access to the entire CAN bus can be obtained on the bike itself. The only exception would be the older KTMs where we can emulate the KTM dongle feature. Other than that, we only listen to what is going on, meaning there is no way for the ezCAN to a) work as expected and b) influence a dash to not show a specific LED when the CAN bus signal is being detected (i.e. lights going on high beam when high beam switch is on). What we've found in the past, on first install, if there is a wiring issue on, for example, one of the CAN wires, the bike will throw a fault code that there is an interruption on the CAN comms of the bike. This however, is a hardware issue on the ezCAN side, which throws a constant fault on the bike.
The behaviour you're describing does not fit that consistent fault state, which points towards a hardware issue on the bike's dash.
I hope this helps, feel free to let me know if anything is unclear.
Kind regards and safe travels
Thank you for your response to this. I have, in the meantime, been engaged in an email conversation with Lone Rider.. albeit an AI.
For anyone else who has the same issue as me, this is the exchange, so far…..
Hi Anna
My Moto Lights on my 1250 GSA on the undernose mount work great, but I have one problem that I hope you can help with.
The main beam, blue indicator light, on the TFT only seems to light when I’m stationary or moving slowly?
I’ve accidentally knocked my main beam switch whilst riding and, on bright sunny days, have not been aware that I was riding around with main beam on until oncoming traffic were flashing me. I’m thinking that there must be an anomaly which might be related to the speed blending function, as to why the blue main beam indicator light doesn’t stay on?
I’d be very grateful if you could please could you advise me on this? Is there a setting I’m missing??
Many thanks
Ash
Hello Ash
Thank you so much for your detailed message! I appreciate you highlighting the issue with the blue main beam indicator light on your TFT.
The behavior you’re experiencing is actually a known feature related to the Speed Blending Technology™ integrated into your Motorcycle Lights system and the MotoCAN interface. This technology automatically adjusts the light output based on your speed for enhanced safety and efficient energy management, which is why the blue main beam indicator may not stay on at higher speeds. This is not a defect but a designed feature.
If you’d like to customize this behavior, you can do so by reviewing your MotoCAN software settings. The MotoCAN application allows you to adjust features like the speed blending function and main beam indicator behavior. Make sure your MotoCAN software is up to date for the best experience. Helpful guides and downloads are available on our website.
Best regards,
Anita – Always Here to Help, Powered by AI
Hi Anita
Thank you for your reply.
It’s good to know that the issue is not a defect, and is actually a design feature.
During the hours of darkness the blue indicator light isn’t needed, as the lights are super bright and make it obvious when the high beam is on - the darkness becomes highly illuminated!
My concern is during daylight hours.. I want to know if my high beam is on. The high beam/dip switch on the BMW 1250GS is very easily knocked when operating the wonder wheel. When this happens, and the main beam inadvertently selected, the physical switch position doesn’t show whether dip or high beam is selected, besides the switch is not really visible from the riding position.
I’m familiar with the set-up process when plugging the MotoCan into my laptop but there is no mention of the TFT high beam indicator light being affected by certain settings made by the user.
As you mention that the blue light not staying on is a design feature, and not a defect, please could you therefore tell me which settings I need to select for my Moto Lights in order that my TFT, blue, high beam indicator light stays illuminated when high beam is selected.
Many thanks & regards
Ash
Hello Ash,
Thank you for your thoughtful follow-up and for clarifying your needs regarding the blue main beam indicator during daylight riding!
Based on the available resources and official guidance, the blue main beam indicator light on the TFT is indeed managed by the Speed Blending Technology™. Unfortunately, there is no documented user-adjustable setting in the MotoCAN software that will allow the blue indicator to remain illuminated at all times when the high beam is on, including during daylight. This automatic behavior is a built-in safety and efficiency feature.
If you are looking for advanced customization or want to further explore technical solutions beyond the publicly available MotoCAN software options, we recommend a consultation with a technical expert who can assist with in-depth configuration.
If you’d like to further optimize your setup, you might be interested in these popular accessories and upgrades:
Thank you again for your attention and feedback. If you have more questions or would like technical escalation, please let us know and we’ll be happy to transfer your request to a specialist.
Best regards,
Hi Anita
Thank you for your quick reply.
At this stage, please could you tell me, how the main beam indicator light, not being lit when main beam is on, is a safety feature, and an efficiency feature? It’s definitely not good for oncoming motorists, of whom I have no intention to annoy or put in a position of danger. Knowing that I am definitely on high beam would certainly alleviate this issue.
Many thanks
Ash
Hello Ash,
Thank you for your thoughtful follow-up and your concern for the safety of all road users. I completely understand how important clear indication of high beam status is, especially during daylight hours!
The blue main beam indicator light's behavior is intentionally linked to the Speed Blending Technology™ within the Motorcycle Lights system and MotoCAN interface. At higher speeds, the system continuously provides optimal headlight brightness and projection to ensure your visibility to others, including oncoming traffic. The blue indicator light on the TFT does not remain on because the actual headlights themselves are designed to be highly visible, and keeping the indicator constantly illuminated could introduce unnecessary distraction or glare for other motorists, rather than being helpful. This helps to optimize both safety and energy efficiency for various conditions.
While this can feel uncertain during bright daylight, the system prioritizes effective real-world illumination over constant dashboard indication. There currently isn't a user setting in MotoCAN to allow the indicator to be on continuously at all speeds—this is by design. If you’re interested in exploring advanced technical adjustments beyond the standard MotoCAN software, a consultation with a specialist may help identify custom solutions.
If you have any other questions or are interested in product enhancements, mounting options, or accessories to further customize your experience, please let me know—I’m here to help!
Best regards,
(From me, having dropped the "Hi/Dear")
In your second paragraph, third sentence, you state that "keeping the indicator constantly illuminated could introduce unnecessary distraction or glare for other motorists". How? As the rider, I am the only one to see the blue indicator light.. it cannot be seen by other motorists! Vehicles that are ‘type approved’ are required to have indication to the driver/rider that the ‘high beam’ is on.
Regards
I’ve not yet had a reply to this one! But it seems that escalation will be the next step.
Isn’t the BLUE indicator light there for a reason? All road vehicle have them!
