Rhino
I might have a cheap soloution to conecting a mobile phone via bluetooth to an autocom system. I curently have a K750i but am looking to get a XDA Orbit soon. I also have a works phone (Orange SPV) When I had a 6310i I found the adpators for it kept falling out due to phone being in the map pocket on My tank bag.
I had been looking at converting a cheap over the ear bluetooth heasdset and breaking out the wires for the headsets speaker and mic too a 2.5 socket and then pluging My autocoms phone lead into that. Whislt looking around for a suitable headset to try I stumbled across the Sony Erricson. HBH-200.
http://www.qfonic.com/product_info.php?products_id=676
It already had a 2.5 socket on it ! As the device is designed like a halfway house between a wired headset and a bluetooth set up.
Only mod I have had to do is shave off some of the plastic around the plug on the Autocom lead so it would push all the way in as the socket is recessed in to the end of the unit.
I tried it this morning on the way in to work and it worked perfectly. I am now going to look at a way of mounting the unit so I can answer calls by pressing the button on the unit and see the caller ID display.
The unit also apears to work whislt on charge, so I will also be looking at wiring in the incar charger that is available to the acessory sockt on My GS12.
