GBgolfman Guest Jan 7, 2006 #21 jump leads Is it OK to use jump leads from a car to the 1200GS? No problem with the can bus and all that?
wessie Registered user Joined Jan 8, 2002 Messages 20,321 Reaction score 8,576 Location Welshpool Jan 7, 2006 #22 GBgolfman said: Is it OK to use jump leads from a car to the 1200GS? No problem with the can bus and all that? Click to expand... Yes, just connect direct to the battery in the conventional manner.
birdseye Registered user Joined Oct 18, 2004 Messages 1,224 Reaction score 0 Location usk Jan 8, 2006 #23 GBgolfman said: Is it OK to use jump leads from a car to the 1200GS? No problem with the can bus and all that? Click to expand... need to be a bit cautious. A car battery is larger, and the alternator could well be too. So you could simply put too much belt down the wires into the bike battery with the car engine running. I'd try it first with the car not running.
