BMW R45 / R65 / R65 LS - Headlamp Assistance Please.
chopper_harris
Standish (M6 J27)
Folks
I did post this in the wanted section, with zero response , hopefully someone may be able to assist here.
The project R80 ST that I bought from Mikey is fitted with the wrong headlamp unit - it has the larger RS/RT headlamp which mounts into the spider.
This will not fit between the ears of the R45/65/ST mounting bracket.
The correct unit is quoted as 189mm - just over 7".
There are plenty of cheap new 7" headlamps, but it would be good to install the correct unit if I can find one at a sensible price.
If you have an R45/65/65LS headlamp that is gathering dust, or even the rim/lens/reflector, please do let me know.
Also, the H4 connector inside the headlamp bowl is too big to pass through the small grommet on the back of the bowl ?
The headlamp wiring is part of the main loom - I don't see an obvious sub-loom connection.
How did they get the H4 connector into the headlamp bowl ?
How do you get the wiring through the small aperture in the R80 ST headlamp carrier bracket - this may be moot with the correct headlamp bowl ?
Can anyone with an R80 ST help me with detail/pics of the correct bowl, and how the loom rises up through the triple clamp to the binnacle, headlamp and the indicators ?
Chopps
Bung me a PM as I have a correct ST headlight and shell in the shed ....
Bubb
I think that I'm sorted with the correct headlamp.
I do need some assistance please with close-up shots from under the lower clamp detailing the correct bracckets/attachment of the headlamp bracket to the lower clamp, and how the wiring loom is routed.
There are the remains of two bendable wings inside the headlamp bracket, I assume that the lower loom is retained there after rising up under the lower clamp.
It would be good to have a definitive picture of this area, please.
Sorry to let you down Re the correct headlight.
I didn’t realise mine was the rt bowl and headlight.
Bubb
Purchased for £25, and a NiB rear light unit for £30 plus £10 combined postage - thanks to gelandestrasse for the heads up.
Hopefully I can get the rebuild back on track now.
Chopper, the guy selling the bits you bought - I'm meeting up with him this week (socially distancing of course). He has some more Airhead bits coming up so keep an eye out.
The main issue now is a decent pair of ST handlebars - the bike was fitted with RT tall bars, which are too much on a naked ST.
I was tempted to the ST speedo, but he had bundled it with three busted tacho units which I definitely don't need.
Yes, please keep an eye open for any ST related parts - thanks again.
You might ask Mikeyboy, he's stripped a couple of STs in the past couple of years, might have some bits left over or suggest replacements.
