Anyone removed the BMW roundel between handlebars /top yoke area before ,an if so what did you use to prise it out with without knackering it ,or the paint on the yoke!!
All suggestions welcome
The actual badge is attached to a plastic disc with a weak impact adhesive, and can be easily levered off.
The disc is about 3-4mm thick and is held in place by a rubber O-ring.
This can also easily be removed with a good wiggle with a blunt instrument.
How do I know so much detail, I hear you ask.....
My badge fell off, and they cost £20 to replace.
I got one off ebay, thanks to a link placed on here.
I removed the disk from mine, and the badge from the replacement one.
I then used "proper" impact adhesive and heat to stick the badge back to the disk.
