bmw battery charger
brummy bloke
in the middle
Probably a daft question,so obviously feel free to mock etc.I have a bmw battery conditioner/charger that plugs into the din socket on my 2016 gs.Can I use this charger on my Yamaha 600 fazer without causing any knackerization to the charger or battery?
Use the clips that came with it and connect direct to the battery of the Fazer
Check the settings on your charger. The GS battery is an AGM, the Fazer one is more likely to be a standard lead acid. The AGM charges at a slightly higher voltage than a standard lead acid, so make sure you have that setting selected.
