Sold BMW Motorrad Battery Charger Plus for standard or Lithium batteries
David Follows
Shropshire
Charging and charge maintenance are controlled automatically using an intelligent microprocessor.
All wiring available to make connection directly via your bikes CAN-bus socket (if present) or directly to the battery using the adapter cable provided.
Both the charger and connections are protected against any short circuits, reverse polarity and overload.
Over long periods the charger can remain plugged in, with charging cycles carried out and the battery being recharged when necessary.
Works perfectly and is in excellent condition.
Only reason for sale is I have recently parted with my GSA and have switched to Ducati
£60 plus postage or collect/can meet if local to Ironbridge.
  • Compatible with all types of 12V battery (lead/acid, gel/AGM and lithium)
  • Easy to use, with a capacity of 6 to 60 Ah
  • Battery level is displayed throughout the charging cycles
  • Easily change between “normal” and lithium battery, or car and motorcycle modes
  • Charging current: 2.5 A
  • End of charge voltage: 14.4 V
  • Integrated electrical protections
  • Connections provided: CAN-bus and adapter clamps
