England-Kev
So armed with my trusty multi-meter, and a cup full of enthusiasm (for enthusiasm, read coffee) I headed out to my little lock-up, and the faulty beemer waiting inside.
So the battery, as it sat having not been played with for a week, has a voltage of 12.98V. So all good there then.
next was to check the voltage with the bike running, well this was harder to do as the bike struggles to run, but perseverence wins through, and the battery tops out at a charge rate of 13.95v or very near to that. so that too is in the ball park.
my next move was to pull the plug from the electronic regulator, now this cured the problem, the bike was back to running perfectly again. So I pulled the regulator from the frame and installed my old good mechanical regulator. This put the fault back into play, so we now know it is nothing to do with either reg.
Next I removed the battery lead, and took off the front cover, pulled the big lead from the diode board, started the bike and it ran great again. So I removed the diode board completely, but could find no outward signs of a problem. So I cleaned all contact faces, for the push on connectors, and reinstalled the board, but the fault was still there.
So I am guessing I have a failed diode board?
