BMW quality strikes agai
iandavid
East Riding of Yorkshire
Out for a long ride today and on the way back the sat nav is down over the speedo. Close inspection reveals that I've lost all the bolts fixing the sat nav bar in place.
Now fixed with cable ties until first service. I think the sat nav prep is done at the factory so can't blame AJ.
The bolts on the actual mount keep working loose on mine ! `fixed with some thread lock
And having said that I think the overall build and finish is way better than it was on the GSA LC
Agree the finish is far better than my GS, obviously the mothership forgot the thread lock on this occasion and all the bolts have disappeared.
Tried dynamic today wow, if dynamic is anything to go by then dynamic pro should be renamed to " fuckin mental"
It is indeed fuckin mental, No faster just madder !
I call it the scary plug
Mine was loose too luckily I noticed it, but it did give me enough concern to go around the bike and check various fixings were tight. No other loose items found though.
Terry
How did you do that cos as far as I can see the bolt heads are inside the plastic trim with only the nuts on the outside. I've lost all but one nut which was sitting down beside the instruments with no bolts protruding. How many should there be?
The locking mount hasn't been a problem on the GS, I see some people have fitted this on the XR although the barrel can't be accessed easily.
It's not the mount, it's the bar that does over the instruments. All it's side bolts and nuts have disappeared!!!
