For Sale BMW R1200 GSA (2010 - 2018) - TRW FRICTION PLATES SET MCC 616-8
Shidosan
Lancashire
Clutch kit consisting of 8 lined discs (No smooth discs) including 3 narrower disc.
This kit is NEW, and can be mounted on BMW R1200GS from 2010 to 2018
Description From TRW/Lucas
MCC 616-8
TRW Clutch Discs feature excellent precision fit.
TRW/Lucas uses different mixtures in the manufacture its clutch discs according to the friction ratings of the OEM components.
The majority of the materials used are Made in Germany.
The clutch discs are supplied as sets without intermediate plates.
Notes: Before installing these components, take note of the correct sequence of the discs.
Before you change the clutch discs, you should check that the springs and intermediate plates are still in perfect condition, and that the clutch body is not showing signs of wear.
Clutch discs should be immersed overnight in engine oil prior to installation. Only use motorcycle engine oil.
Bought to replace the clutch on my 2017 1200 GSA Triple Black but traded in the bike before fitting.
New Heavy Duty Clutch Springs Included.
£40.00 posted to UK
