De catted with Y piece and standard can. Runs a tiny bit rich and occasionally pops on the overrun but turbine smooth power on my 37,000 miler![]()
Ditch the can, run cat and stubby. Better low end torque and breathing. Barely more noisy than standard. Mine was a bit better on fuel too, probably because I could often be in one gear higher. Fuelling was great, sold the bike at 96,000, over 60k done with that exhaust setup.
Tested today
Great with y pipe stock can .
Tomorrow going to clean / swap
O2 sensor as bike is surging a little
On idle .
Eny thoughts
Same here. Just over 60k miles so 40+ with this set up. It also allows equal sized panniers if you need that sort of thing
