Bolt/Nut Caps
  • Thread starter Thread starter MooMoo
MooMoo
I've finished installing my PIAA 910s, all I need now is some dome covers to go over the bolt/nut (17mm nut so the spanner says)
Anyone know where I can get a pair?
Moo
Nuts needing a 17mm spanner are M10 if that helps.
How much thread is left showing? Enough for a nyloc nut? If so http://www.namrick.co.uk will flog you some stainless steel ones. If not, probably a traditional car spares place would be able to supply something.
There isa very good nut & bolt specialist in Camberly, which is not far from you, sorry I cannot remember there name, but they are on the A30
Andrew
Moo
How heavy are these lights :eek: :D have you snitched them from a football stadium
I'll post a piccy later
What I'm after is plastic domed cover to hide the nut and end of the thread.
You will see what I mean from the pics
Moo
Firstly, let it be known that I am NOT encouraging anyone to steal. :spitfire
BUT........if you just happen to take a walk to your local park and have a closer inspection of the wooden benches, or more importantly under the wooden benches in your local park.
Then I think that you just "might" find exactly what you are looking for. :o
Hopefully, you "might" even be armed with a small bladed screwdriver, as front door Yale keys tend to bend. ;)
But I am NOT endorsing such actions, you understand :nono
I assume that you noticed them after going arse over tit off your peddly bike ??
:D :D :D :D
AHC
The place in Camberley is called AHC Fixings and Fastenings, 415 - 417 London Road Camberley Tel 01276 709609.
Hope this helps
Matt
I suppose I better be a good father that I am and take the little ones to the park later then :thumb
Moo
Moo
Now I do hope that you are not going out with the intention of doing something illegal, by any remote chance?
:nono
