Bouncing Main Stand - Advice
Roge
Stroud, New South Wales. AUSTRALIA
Anyone had problems with the main stand bouncing off road it rebonds into my heel on the bumbpier bits. Has anyone put a second or a stronger spring on or any other mod to stop this happening :nenau
Yes this can be a real pain and distracting. When I'm on longer trips I don't tend to use the main stand often so have used a cable tie in the past.
Hi Tim, Its a real pain I thought of tie rapping the thing or taking it off altogether but I am on these tracks everyday on the way to work and the main stand is useful, my heel is taking a bashing though. I might loose it when I fit the Y piece if there is no mod to fix it.
When I had my Y-peice on, I bent the bit with the bump stop up on the y-peice so the center stand went up higher. ;)
