braided hose
  • Thread starter Thread starter sigood
sigood
Hi
Has anyone had problems with fitting of Goodridge braided brake hose to GS 1100 ? The two going to the front callipers seem to be under a bit of tension as i had to put a slight twist in them for them to line up with bolt hole.Thought it may cause bolt to loosen after a while.Lined old rubber ones with new ones to make sure i fitted them to their correct sides.
Not sure if i should have stayed with rubber as these s/s braided type are quite rigid.
Any pics would be a great help and of the routeing of the long one down to the short ones i have mentioned above.
Simon
