Braided stainless brake hose --
Steptoe
Him/Bloke/Fella.
S/W London.
These kits contain everything you need, all in stainless steel, including the brake line banjo bolts and the swaged ends ( which aren't stainless on another well known make), and end fittings.
R1100GS / 1150GS ABS - full set (front & rear) £98
R1100GS / 1150GS non-abs - full set (front & rear) £87
Kits come with a lifetime warranty .
fitting service available for those that require it.
And don't forget the complete stainless steel bike fitting kits, every nut and bolt in stainless steel for your bike.
all for £26
Steptoe's stainless Emporium :D :D
Re: What's happened to my brakes, oh the ignition's off
Rod Souter said:
Do they fit the ABS-servo version?
Rod
Not sure if its recommened on servo bikes .
:confused: :confused:
I'll find out on monday.
The braided stainless steel brake lines come with clear plastic coating.
Made by HEL , one of the best quality brake line makers.
you won't get them cheaper.
Whats the cost for a set of non ABS, fitted at Pricetown?
and what if something "goes wrong" i.e. a banjo bolt snaps in situ , plus don't you want to go on any rideouts, and what if its pissing down, i don't want to work on a weekend off.
idontwanttocarryloadsoftoolsaroundallweekend.
you bring the tools and brake fluid and i'll fit them for nothing .
That's more like it, I'll bring tool kit.
It was a bargain at Aldi, its got pliers and all sorts of screwdrivers, there's even a selection of Rawl Plugs and screws. :D
.....what do you need?
(as if you won't have them in those loverly H&B panniers like wot I got now. :) )
Joking aside.............
What tools would be needed to change a set of hoses. If I've got them I'll give it a go, while you watch.
A bit like being an apprentice again.
Anyone who fancy’s buying a set who's there would have an better idea of what to do and what not to do.
Steptoes Brake Bleeding Course?
Only an idea.
shall i order you a set for your bike, what year is your bike, ,
i'll bring my special 14mm brake banjo flexi head multi swivel attachment, you bring the fluid, 1ltr minimum, your usual Liddle quality will do for you .
First registered 01/02/2001. Order me a set and I'll get some reclaimed fluid from our local scrap yard, 30p a pint. Bargain.
Thanks Neil.
Well that's Steptoe stiched up for the weekend....who shall we do next???
:D :D :D
