Brake bleeding on 1100 with ABS?
Tsiklonaut
GS pervert
semi-homeless
Brake bleeding on 1100 with ABS (should be the basic one, not II or integral)?
Is there anything i shoud do with the ABS unit or should i bleed the brakes on the same way as non-abs bike?
The same way - at the caliper.
unless you've completely stripped the abs unit down - then bleed it at those nipples first. - otherwise leave them alone.
I would bleed the ABS unit as well. . When I did mine a couple of weeks ago, the fluid that came out of the ABS unit was filthy.
The principle is exactly the same as bleeding the brake calipers, so you should find it straightfoward.
Bob
