Brake Disc
GedJack
Lancashire, God's country !!!
I've just purchased a 17 inch wheel conversion for my 1150 GS. I need some discs for the wheels. Can anyone recommend a good disc and where to get them from.
Just make sure to HEAT The old disc bolts up plenty with a hot air gun or gas blowlamp !!!!
They are loctited by factory Pink POOP on the threads of the bolts M8 thread 25nm torque
Start with the recommended pressures for the Rockster ,r1150r and work from there
Wheels
Glad you got some wheels chap, assume you got the RT speedo drive as well. If you have ABS don't forget to check the shims/clearances:D Cheers:beerjug:John B
