Brake discs 1150gs
sidpick
Worthing, England
Hi all, just checking my bike over prior to ordering bits for yearly big service.
Measuring the brake discs (as the rear looks pretty tired) I've got the following numbers:
front L= 5.09mm (off side) front R = 4.86mm
rear measures in about 4.96mm
fairly even wear all over but the rear looks more heavily worn than the fronts.
Do they all need replacing or are they OK?
Thanks in advance!
Sid
Thanks in advance!
Sid
Service limit is 4.5 mm. They should be OK.
Pekka
:rolleyes::rolleyes::rolleyes:
BTW. There is a mark on your disc which will indicate the minimum thickness and can be either 4.5mm or 4.0mm as found on my front wheels (I have a spare set). :thumb
