Brake Fluid, critical and often ignored!
IrishGaucho
Cork, Ireland
Hi folks,
More often than not, I see bikes with disgusting looking brake fluid, lads completely ignoring the service maintenance schedule for it, etc...
So here's everything you need to know about brake fluid, why it's so critical and how to stay on top of it.
Hope this helps!
Exactly this. I remember buying an old bike and running it for a couple of months before changing the brake fluid. It transformed the soft spongey brakes.
Well explained video as always, only 1 point I would add is when changing brake fluid, firstly check the reservoir for pieces of dirt specially at the bottom of the reservoir that will build up there overtime. Regularly removing, using a lint free paper, (blue paper) every time before a flush is started. Keeping that fluid clear and all parts working properly.
Agreed, it does make a huge difference in feel! But also, and this is the danger of it, you can be used to the feel as it degrades over time but on a "spirited" ride it can boil and fade away which is the riskiest thing ever!!
Well explained video as always, only 1 point I would add is when changing brake fluid, firstly check the reservoir for pieces of dirt specially at the bottom of the reservoir that will build up there overtime. Regularly removing every time before a flush is started. Keeping that fluid clear and all parts working properly.
Thank you!! And yes, 100% agree with your statement. I didn't focus on the process of doing a brake flush in this video but that's an absolute valid point! :)
Thank you for your well scripted videos, I always welcome them, and enjoy all your content worded perfectly each and every time. :D
I've recently changed the brake fluid on my GSA. The fluid was last changed two years ago, it says so on my invoice.
I was a bit surprised to find that when I tested the old fluid, it had a water content by volume of over 4%.
Thank you my friend, I really appreciate your kind feedback. I do put a lot of time and effort into them, so it's great to hear/read this :)
Right? That's one of the points I try to drive on the video, the 2 year schedule is an average and while valid most of the time, it also depends on other factors.
Also, I've heard some horror stories of shops just replacing the fluid at the master and not doing a proper flush. So at a glance it looks like new fluid but it'll quickly mix with whatever is on the lines already and won't take much to already have a higher water content already.
