I got fed up with the amount of low speed brake judder I was experiencing and didn't fancy shelling out £140+ with Steptoe for a new pair of front disks.
So I did something I neglected to do all summer - give the calipers, pistons and pads a damn good clean.
I found one stuck piston and made up some wooden blocks to stop the other pistons coming out and used a small G cramp to stop the one opposite coming out.
Then a few good squeezes of the lever and out she popped! I got it out about 1cm - as far as I dared (no idea how deep they are) and cleaned it all up with a toothbrush and some mild car wash solution(fairy liquid's got salt in it, apparently)
I did the same with all the other pistons and scrubbed up the calipers where the pads 'slide/sit'
I put some 800 grip paper on a flat board and gave the pads a bit of a scrub as well.
Once everything was back together and after a brief test ride (no - I didn't end up in the hedge opposite the garage as I'd remembered to pump the brakes until I got resistance before I set off
) I returned with a cheesy grin as the pulsing/juddering has gone
So, before you shell out big bucks on new disks, try a clean and scrub! You never know
