Yesterday I was riding her and all was good... today I ride to work and the brake light stays on. Any idea what the problem could be? Other than the brake light all seemed normal.
Can you isolate whether it is the front or rear switch causing it? If it is the rear it will be clogged up with sh*te, give it a good soaking with WD40 and activate the switch many times, this will fix it.
Check the rear first, look under the brake lever and you will see the switch mounted behind it's pivot. There is a plunger which operates the switch when the lever is pressed, my bets on it being mucked to the eyeballs.
as St. Eptoe says,
there's a lot of different switches.
on mine (R100GS '91 model) the front has a habit of sticking if not used enough
proper job is to replace i suppose, but it's a pain in the butt (read as; i'm lazy and tight fisted )
so,
i remove the lever and ease out the sticky bit (about a 1/4 inch - no more )that the lever depresses with a small needle nosed vice grips (yes - i know, i'm a butcher - it works) - apply lots of WD40 and clean it as much as possible - i use kitchen towel and Q tips. waggle it in and out GENTLY with the little vice grips until it's as clean as possible.
if it works you'll find the lever returns fully 'out'. there will be no 'slack'.
IF yours is the same as mine - that'll get it working...... for a few months at least.
