So I've been trying to solve the pulsing issue on my 1150 and am struggling to work out exactly what the issue is.
I've replaced the discs, the mounting hardware (spring washers and bobbins) and added the 1mm washers behind the disc as the mounting points on the wheel were looking a bit worn.
I'm still getting pulsing through the lever so have been doing more investigating. I've found the point at which the pulsing happens but there's nothing obvious about the discs not being mounted straight which I was expecting to find.
I tested it one side at a time and found that bizarelly the pulsing happens on both sides at the same point (albeit slightly more obvious on one side). Because it's the same each side it makes me think it's not a mounting point issue but perhaps something about the hub or axle. I don't know anyone with another 1150 to start switching parts to test unfortunately.
Anyone got any ideas / experience with this?
