Brake upgrade.
Galfer do a 320mm front brake upgrade, available from Motorworks ( getting the bits together to do the same on my gsa at the moment using RT discs and caliper spacers )
Can I ask where you found the caliper spacers? I've got a similar problem. But I dont need the full galfer kit, just the spacers.
Got some turned up locally and combined them with longer titanium bolts , will have to dig them out as the 1250 is out of warranty and will be getting the bigger discs
Look up online for Radial Caliper Mount Spacers , they cost buttons
Couldn't share the details on the machine shop, I dont have a clue what to ask for, but if they could reproduce a set for me I'd be eternally grateful.
Larger rt discs are 320mm whereas gs ones are 305mm. If you look online for 7.5mm spacers for radial calipers they aee what you need
