techno
Had a quick search on here but not turned up anything..
Just tried to take my screen off and couldn't undo one bolt. Just kept spinning. The brass insert had become loose in the plastic housing (or the bolt was too tight for the weak plastic/brass mating). Got it off but had to pop the brass inner out.
Crap design if you ask me as the same thing happened to one on the beak when I was fitting HID ballasts!
Anyone done a repair that works and what did you use? I was thinking of Araldite. Obviously has to be strong..
Don't fancy replacing the whole front as it's a big job not to mention expensive (unless anyone got one lying around cheap!)
