Brembo recall - maybe?
wessie
Welshpool
This article details that Aprilia are recalling Brembo master cylinders to replace a plastic component with a metal one
https://www.asphaltandrubber.com/recall/brembo-brake-recall/
"The issue stems from the Brembo’s popular PR16 radial master cylinder unit (the master cylinder that is often paired with the Brembo M50 calipers), which apparently can crack internally at the piston, which can then lead to front brake failure. "
Nothing to worry about....
Cut n paste from A&R.
Brembo SpA, a leader in the production of disc brake systems for vehicles, following the recent publication of some articles by the international press, mentioning wrong information, points out that:
-Thanks to the constant quality monitoring over its production processes, it has uncovered the possibility of defects to the piston of the front radial master cylinder (diameters 15mm and 16mm), sold between 2015 and 2017 and mounted on some motorcycle models.
-The only manufacturers affected are:
Aprilia
Ducati
KTM
MV Agusta
TM Racing
Moto Morini
Horex
-The recall does not affect other manufacturers nor other master cylinders, or master cylinders sold as Aftermarket kits through the Brembo distribution network.
Brembo promptly informed the manufacturers of the problem so that the owners of the aforementioned bikes could be informed and invited to have the part replaced at the nearest dealership.
