ColinFromDevon
Hi, I have recently tried Brisk Spark Plugs in my new to me 2003 R1150R twin spark as part of my tuning it up process, I want to share my story and hear from anyone else who's tried them. Upon fitting them I straight away noticed a small but worthwhile difference, especially at very low revs in low gears, nice. A month on and 750 miles later, after washing the bike one day, (I think the wash/water started something) I rode off and started having a problem at low revs/wide throttle and at full throttle 4000/5000rpm, bike would stutter cough and temp' stall, quite nasty, this problem went on for some days while I tried to work it out, after ruling out fuel problem I found my stick coils were looking bad, corroded on the outside quite badly, thought aha that be it, and the water from hose wash must have gotten in around the coil. I bought 2 new coils expecting that to solve it, esp' as one of the written about syptoms of a faulty coil is that your bike will run ok for first few miles of a ride and then it goes wrong (once warmed up a bit) and this is what was happening, consistantly. But changed the coils and still had the problem ? I took the tank off and went through every ignition system lead and sprayed WD40 into every connection & checked they all were good and tight and with no water in them. But still no joy. Then I thought I'd change the plugs over back to original, just to eliminate possibilties and to my surprise it cured it. So were the corroded coils a false lead? Was it the plugs/or plug that had failed by themselves ? Or had the bad coils somehow damaged the plugs - which I think would be weird, but maybe?? So I contacted brisk using their online contact form 1st and then with 2 more emails, telling them the whole story and asking their opinion and whether the plugs can be sent back and tested? but I never got a single reply, which I think is pretty poor, they have just totally ingored me. Someone in the trade spoke with me that said Brisk might be reluctant to email honestly about possible faults as once in writing it can be reproduced elsewhere online and make bad publicity. So I'm left in the dark and if Brisk know anything they arn't talking. Anyone else got experience of these with a twin spark engine? Anyone know enough about the mysterious world of electricity and ignition to know whether the coils might have broken the plugs?
) that if the whole HT system is in tip top order, the Brisk plugs may well provide a much cleaner burn, more power and so on through being a better source of ignition for the fuel/air mix, but once the HT system falls below a certain level of efficiency, they will work a lot LESS effectively than the traditional plugs
