broken cast metal bit on clutch master cylinder
Not open for further replies.
Northern Monkey
preston, lancashire
Chaps,
in replacing my handle bars i may have been a little over enthusiastic when prying the cast clamp open a little to slide off the bars.:blast
My question is this - does the cast clamp come as a complete unit with the master cylinder - if so how much are they likely to be?
Can cast metal be welded/repaired or would loads of araldite hold everything in place?
any help as always is appreciated! :comfort
Chaps,
I'm afraid I can't answer the first two questions (I have an 1100 - cable clutch) - a call to Motorworks or Sherlocks would probably help you.
However I can say that Araldite isn't an appropriate repair and it's very unlikely that a weld (assuming it can be welded at all) would be strong enough on a casting like that.
Brace yourself for having to buy a used mastercylinder :( - Motorworks sell them for £64 - you may get lucky with a wanted ad on here.
Damn - if I knew how much you needed it i'd have charged you more :thumb
Steve
