builder/double glazier needed
vilguy
SW Scotland
Just wondering if there are any builders/ double glaziers in the nearby vicinity that are short of work? I have a quote from my local double glaziers but was wondering if anyone out there is short of work could match it?
Id rather give it to a fellow tosser :)
Im in Aylestone, Leicester
Job is to remove 12 glass bricks, cut out wall to extend window area down, and supply & fit 1 off, bottom opening pvcu unit with frosted glass, size - approx 1200 wide X 900 deep, with restrictors & trickle vent. Finally brick up air vent 6 ft to the left with the bricks from the cut out (so they match)
Window is on the ground floor so nice n easy.
Best quote so far - £380 Inc. Vat
Any takers?
Put it on the Larf site, Slic may take you up on it
Similar threads
