Bumot Racks for 690E
Arsey
Guernsey or Plessala
Just popped up on Bumot’s Facebook feed so assume these are new ?
“Xtremada soft panniers & KTM 690 Enduro R!
Designed to fit directly BUMOT pannier racks the Xtremada soft panniers provide 74L of total capacity – 2x 35L panniers plus two 1L pockets on the front and rear of each pannier. Dual-layer construction of 1100 Denier DuPont Cordura and 650g vinyl-coated polyester means these bags are built to survive in the roughest of conditions while still minimizing weight on your motorcycle. On the outside wall of each bag, a third reinforcement layer of Cordura over a nylon insert provides for additional abrasion resistance if the bike goes over. The bag is securely mounted to a 4mm aluminum plate which offers a strong mounting point to attach to the racks. Reflective 3M strips are sewn on either side of the bag to improve visbility and safety in low-light and nighttime riding conditions.
The Xtremada soft panniers attach to BUMOT Defender racks using BUMOT's innovative stainless-steel, exterior mounted Quick-Release mechanism. The QR design allow you to lock the bags to the rack directly.
The rear-mounted quick release lever allows you to remove or install the bag within seconds, and no adapter plates, brackets, or other hardware are required for install.
A roll-top enclosure with two straps and quick release buckles allows for quick access to the contents, and the straps can be used as tie-down points to lash additional gear to the top of the bag. Inside the Xtremadas, a dry-bag liner ensures the contents stay 100% waterproof.
The inner bags are removable to make it easy to carry your gear with you while leaving the Xtremadas locked to your motorcycle.”
