Hi,
Just started using Calimoto. Planning routes for upcoming trip. Experimenting and getting used to the software.
Calimoto is good and easy to use. Using in iOS on MacBook to set up routes. Syncs with the Calimoto phone app.
Would prefer to use my BMW Nav V on the bike rather than my phone on a mount. Graphics better on Nav V rather than just a turn by turn instruction on the phone in Calimoto app. Although the latter would be doable.
Downloaded my planned and saved route from Calimoto to my iOS MacBook files. As GPX file. Ready to transfer to Nav V.
To be able to open GPX file in iOS and see route had to download “GPX Review” from App Store. Just shows route on a map when you open the file.
(Thought I might be able to open the GPX file using BaseCamp as this is Garmin and compatible with Nav V. I no longer have BaseCamp. BaseCamp finished and no longer supported. I believe?)
Plugged in Nav V to computer. Opened GPS in Nav V (on MacBook). Dragged and dropped the file from computer to Nav V. Done.
Although the route does import to the Nav V, it splits it into several shorter routes.
Quote on Nav V screen - “Has more than 29 via points. Route was split into 14 trips”. So 14 separate routes appear in trip planner on Nav V. Not ideal as you would need to open each section in the correct order as the route progressed? The sections are not in chronological order on the trip planner.
For this route I only entered a start and finish point in Calimoto. Nav V seems to add in several via points when you import. Hence the message on Nav V.
Or, is it “GPX Review” that adds in the points first before importing to Nav V ? Don’t know.
If you enter a simple start and finish directly in Nav V it does not slit it up. Just plots the route.
Does anyone know why the imported Calimoto route gets split into several shorter routes?
Can this be overcome? Is that just the way it is?
Want to set up several round trips and routes on Calimoto and import to Nav V without Nav V splitting routes into several short stretches.
Any advice would be appreciated.
Thank you
Archie
Thank you
Archie
