Hi all,
Yesterday I had cam chain slide failure over here in Tierra del Fuego, Argentina.
Oil warning light came on and strange sound from RH cylinder started 20km after the Argentinian border.
I pulled over turned off engine and opened cylinder head cover at the side of the road.
I found many broken plastic parts and a small piece of metal. More careful check revealed that cam chain guiding rail had shattered!
I got bike and myself to Rio Grande and later today I need to do a bit more careful check, but I guess also chain tensioner has failed.
Bike has already over 330 000km, so I guess this is the main cause for the failure. I am also wondering if the spring in tensioner failed and this caused chain to rattle and finally destroyed the guide rail.
Has anyone had this kind of failure before?
I have couple of options:
Option 1: Try to replace chain guide rail over here and keep my fingers crossed that nothing else has failed. Risk, if there is any material in the engine, it might cause catastrophic failure at any point.
Option 2: Fly the bike back to Germany, open the whole engine and do a proper rebuild.
Any suggestions / comments?
Br, Hemuli
Br, Hemuli
