geek
= moderation
= very good moderation.
= moderation
Gets boring this
Piss takes and jokes to the relevant forum please.
Dahoum
Twists Off Dude! Not Pulls they'll wreck all round them if you tell them that!!!take the LH tank side cover off, then the round slotted cover from the fuel pump (pulls off).
I'm actually very suprised just how many problems the BMW's have
Try a corellation of miles covered against faults occured and against faults not repaired under warranty and I think you 'll come out with a favourable BMW result!
Not a world expert on this but I've had 2 fuel pump relays fail on me. Now carry a spare ( cost £50 ) in the top box. Also have a spare ring antenna in there. Both are simple to fit/change so peace of mind all round.
My GS cut out in the outside lane of the M1 through roadworks last night. Hazards on, considerate car drivers for a change allowed me to swerve across to the hard shoulder that wasn't there, but managed to get parked up.
Gipsy...Fuel pump relay...no problem. But how do you replace the ring antenna, and then code it to your key? I know that this is possibly sensitive info' so please PM me if you are not too keen on splashing it all over this site.
Cheers......![]()
no coding needed, it's the ECU that stores the code.
not a sensitive issue, it won't help you nick one. it's just replacing a component of the system.
youngsters do. But I cant understand why BMW havent changed the design of the pump to completely avoid the problem. Sticking with faulty designs (remember the Stag? or Triumph oil leaks) was one of the things which brought down the British industry
Dahoum, just wanted to say good work getting rid of all the silly comments. I don't mind the sillyness in b&b, but it's a bit sad that people are doing it in the 1200 technical forum (and the newbie's forums) now, they might as well post remarks on every thread in here.![]()
