can someone educate an idiot ?
stever1
Elderly n deluded I’m told.
Back in Hull
I have the route Napoleon on a garmin satnav but I want to reverse it. I can't find out how to do it. I've looked in basecamp help files and the way they say doesn't seem to be right. Any help gratefully received ..................Richard :D
I can't check at the moment, but pretty sure you can invert the route
The word you are looking for in BaseCamp is ‘invert’.
From memory, on my Mac, I highlight the route and then chose ‘invert’ from the options offered up.
Select "select mode" i.e. the cursor is a pointer. Tools->Select
Display route on map
Double click on route on map.
Route properties window pops-up
Invert button at bottom of window.
Again BC not as simple as Mapsource.
I'd expect a right click on route name in LH window to display route properties window
