Can you repair a bulb filament ?
turnipbmw
Aldbury
Electrician at work was telling me that if its only broken on one side,
1, hold the bulb so the two parts touch,
2, gently 'flash ' the bulb by connecting a 3 phase supply to +/- terminals
3, extra amps will weld detatched parts together.
probably worth a try in the current financial situation :thumb2
Please make a video recording when doing this..... I need something to laugh at and submit to the darwin awards.
Sent from my GT-I9300 using Tapatalk 2
Does it have to be 3 phase? Can't see what difference that makes.
PS: My legal representatives number is 020 564 2381
Apparently an EM pulse from a small tactical nuclear weapon has the same affect but don't forget to duck and cover, oh and some lead shielding for your testicles. :)
Brian
i just need to work out money saved on bulbs vs. cost of installing 3 phase.
will it fix HID burners as well? every little helps.
there is a cheaper way but it involves acid/caustic bathing candles to remove +/- ions,
you then use the positive flame on one bulb terminal and the negative flame on the other.
when the +/- heat combines it creates enough heat to weld the broken filament.
next up - some tips on retreading tyres using rubber mats and vulcanising fluid:thumb
My mate wires his indicators back to front every now and then..........Says it saves the 'on' bit from wearing out cos it's the 'off' bit for a while and evens out the wear and makes the bulbs last longer!:thumb
I turn my gas meter around every now and then, for the same reason.......honest :green gri
You may laugh, but:
Back in the days of carbon filament lamps, when the carbon filament broke off a leg, it was common practice to rotate the lamp until the filament made contact again. We are talking circa 80-100 years ago, but it was done on a regular basis.
Myke
Myke
You must have a great memory?
Bulb wiring
Just remember to check your polarity
Red to Red
Black to Black
and
Blew to fcuk:aidan
