Hi, I'm new here and fairly new to BMWs so hoping for a little help.
I'm in the process of removing the FD on my R1150GS because something is leaking oil. So I guess it's the seal. I have searched, read about the seal replacement and so on, but I#m stuck at the next stage.
Problem:
I have the two pivot bolts out without much trouble but I can't manage to pull the FD all the way out. After a lot of wiggling and tapping with a soft mallet it came back out of the paralever about an inch or more but I can't get it all the way out. Is there something else holding it or do I just need more force?
Problem:
...... it's not an easy job, the two parts of the shaft are seized together. Hence he also won't be able to grease the splines
