jack.pe
Guys,
I did a plug chop today and the plugs were mostly white, (running y pieve and straight through pipe..)especially the tips and eletrodes. i have read that removing the cat code plug reverts to a standard setting and makes the bike run richer so was going to try but some of the psots have confused me, the cat code plug, is that the plug that goes into the Y piece? or is that the lambda sensor? or are they the same thing??
If I remove the plug do i have to reset the ECu? if so how???
Thanks.. going touring this saturday to italy and need to get it sorted before then...
Jack
Jack
