Centech mounting plate
Delboy777
In a Remote area apparently.
Hi peeps, I was reading a post on here a few days ago where someone had sourced a mounting plate for a Centech fuse box. But im blowed if I can find it now. Can someone point me in the right direction. Cheers.:thumb
Ok Bendy, thanks for that. I was reading a post about a mounting plate for the Centech that mounted beside the diagnostics plug. But I cant find it now.
I have seen them mounted next to the diag plug on 11xx bikes never on a 12 though
there is space to mount one in front of the throttle cable splitter box but it isn't very accessible if a fuse blows
I have a wild n whacky option.
Fit a small gel battery under the petrol tank and use an 8 cell Ballistic battery (also v small) in the battery box. You then get lots of spare space. The 8 cell won't cope with winter cold but it's so small you could unplug and take it into the house so it's warm in the morning.
Alternatively use a bigger Ballistic under the petrol tank and leave the battery box empty.
Ive bought a Centech distribution board Bendy so that i can tidy up the rats nest of wires coming from the battery. Im looking for best mounting point for it.
That was my point. Move the battery to under the petrol tank beside the ABS unit, then you have the whole battery box to make a tidy wiring and fuse (and whatever else you like) container. But the idea wont work with normal size lead acid batteries hence the Ballistic suggestion.
