CHAIN BREAKING/RIVETING TOOLS
Lee Frost
Kernow
I was out trail riding alone the other day and my chain snapped. Fortunately, it had a master split link with a spring clip and that broke, so I was able to replace it with a spare split link that I had. Well, not quite, as I didn't realise that I needed a master link press tool to compress the link enough to get the clip on, so I ended up hobbling home with just the spring slip holding the link together! It snapped again half way home, so I bodged it again with another spring clip and made it the rest of the way.
I don't want the same thing to happen again, so I need the right tools for the job!
I'm going to rivet the new chain when I fit it rather than use the split link and clip, but that makes life a bit more complicated if the chain ever snapped on the trails as it';s more difficulty to remove a riveted link.
There are loads of chain breaking and riveting tools around, but can anyone recommend one that will push out a rivet without needing to grind the rivet head off first? I can do that at home, but not on the side of a trail! Motion Pro make a big chain tool that will do that, but it's a bit big and heavy to carry on the bike. Is there a cheaper/lighter alternative that will do the job?
I'm also going to buy a master link chain press so I can fit a split link and clip if I ever get another snapped chain. Motion Pro make one for about £35, but there are identical Chinese copies on Ebay for £12-15. Anyone bought and used one of the cheap copies?
Motion Pro
Launched ok no further…
However with a pair of KTM pliers you can use them to compress the backing plate enough to get the spring clip onto the grooves
Motion Pro
Thanks John. Having looked at reviews etc it seems the Motion Pro PBR chain tool is the best option so I'll probably go for that unless someone recommends a cheaper option that will push out a rivet, rivet a new link and press the master split link to get a spring clip on.
Carry a cheapo spare chain already cut to size.
Makes sense, though I'd still need to compress the master split link to fit the spring clip on and I'll still need a chain breaking/riveting tool to sort the snapped chain out once home, so I might as well carry that tool with me and repair the snapped chain.
Not if you use a non-ringed chain - which would be fine as a 'get-you-home' job - you wouldn't need any tools other than a flat blade to push in the circlip. Non-ringed chains are also lighter to carry.
Thanks Greg. I think I'll get one of those ordered! Do you have a 114 link?
I carry a non O ringed split link in case I need to to join my O ringed chain.
I'm not carrying heavy chain breakers etc. If the job needs that then the bike's not going home under it's own steam.
I *think* I checked it :unsure:
I'm also thinking a shorter pin length would work anyway as it won't necessarily have the O rings fitted. I should probably check again when I find a bit of old chain lying around. If it doesn't work, I'll ease out the holes in an O ring split link.
Thanks for the heads up :)
I’ve ordered a non-ringed chain from Greg that I’ll carry in my tail pack and use to get me home if I snap another chain. Of course, it’ll never happen again if I’m equipped to deal with it!
Yarkto, That looks good what brand is it please so I can order one
The genuine DID tool is similar but a bit chunkier. Last time i looked they were about £110, but knock offs are available for a lot less.
No experience of either. I have a Sealey chain breaker set, which does work, but feels like it's going to break at any moment in use.
