walkon40
The rear brake pads on my 2000 1150GS (ABS) are worn down. I know how to change front, but whilst looking at rear calliper, the setup looks different. What do i need to do to change them (i.e. what do i need to take apart where?).
Martin
Martin
. Got pads out ok, cleaned all up ok, then desaster? struck. Fitted first pad in, second difficult as no space. Pushed pistons back, re-fitted first pad and now of course the pistons are pushed in too far and i can't get them out again. Meaning i've got one pad in, the other one out ... How can i get the pistons back so that i can fit both pads (which i think is the idea, isn't it??) without doing a brake fluid change as well (i.e. draining the system ...).
