Changing from Dynamic to Road to Rain mode whilst on the move
Nice 'n' Fat
Marlborough, Wiltshire
Am I the only one who didn't know that you can swap between these modes whilst on the move without stopping by selecting the preferred mode then blipping the throttle with the clutch pulled in?
Perhaps you should.............................you'll fit in well, in the WC section:D
I'm building my own starting with this
you don't need to blip the throttle just pull the clutch to activate.
Martin it doesn't always change doing it that way, whereas clutch in & throttle closed changes the mode and suspension straight away.
I dont blip or pull clutch in,jusr toggle through mode switch and select . Done.
No it isn't done. Doing the above preselects the mode which will then be selected the next time you pull the clutch in, if this isn't done within a certain time frame it will 'forget' what you pre selected.
With the clutch it activates immediatly. Or you can just wait for it to change, I think.
If you select your mode, but then don't either shut the gas completely or pull the clutch in, it'll cancel after one minute. So it won't just change - you have to prime it, then activate it if you like.
Once Enduro Pro has been added to your software, changing mode won't change suspension settings - It'll let you stay on say say Normal, however you select the engine mapping.
Personally, I don't get why riders would change engine mapping. To me, your throttle is you throttle, and it's yer brain that controls it. My brain will give me the right amount of gas on a wet bumpy roundabout - why would I keep swapping between different throttle settings and add something new that I have to compute? One throttle action, and I know how it works ....
