Changing rear brake fluid Q
Baza 07
Wirral Merseyside
Hi all I have a 2010 BMW R1200GS TU, I also have a 250ml bottle of Hyspin V10,dyou think 250ml is enough to renew the back brake fluid,plus any tips would be appreciated
Cheers Baza 👍
Edit,,,,This is the first time I’ve tried to do this,also I have a Motoscan scanner 😉
I thought Hyspin V 10 was a hydraulic fluid for the BMW clutch.
Use a Dot 4 Brake fluid in the brakes. I use Brembo but any good dot 4 will do.
Do not put clutch oil in the brakes or brake fluid in the clutch.
I'm curious as to why you're changing just the rear brake fluid. DOT4 fluid costs pennies and the bike will only need a small amount so change both front and rear. Do not use mineral hydraulic fluid!
If you're not absolutely sure what you're doing with brakes it's probably best to get someone who is to do it for you. Be safe.
Starting with the rear mate,if that’s a success I’ll do the front next, 👍😉
