CHanging the speedo face - how to?
mvrandery
London
Hi all
Just got a replacement face for the speedo from ebay. Need to change to mph one.
I just can't figure out how to open the speedo and remove the needle to replace the face
Any tips would be appreciated very much
Mehul
Face change!
Mehul
Having just done my '05 GS it is really easy. Remove the speedo unit from the headlight (3* spring washers in the rubber bungs). Remove the glass facia (four screws on rear) and prise off speedo needle, face is tacked on with a little adhesive but it's easy to pop off. Replace with mph item and reverse the above steps. Don't forget to get dealer to electronically change the unit of measurement (€20 max!).
Hope this helps
Andy
Andy
Thanks very much, exactly what I was looking for.
You didn't happen to change your headlamp too? If yes, could you let me know how that's done?
Mehul
Headlight change...
Mehul,
I swapped mine for a UK one. Enquire on here if there are any interested parties willing to do a swap if so it's easy to do it with the speedo job. Two side screws, two plugs (one bulb) and a mounting spigot are all you need to remove/adjust.
A BWM OE headlight will be around £250/300 so it's worth checking around before going down the OE road.
Hope it's usefull - Good Luck
Andy
