I've got a full width radiator, and no over heating problems at all.
If you do it, or even replace with a standard unit, cover up the holes in the back of the front fender to stop the replacement filling up with crud.
I'm also running a unifilter main and pre-filter, which requires the top of the air box to be removed, coupled with the remus header i now have fitted, the bike now goes like wylie coyote's acme rocket
Not tried the Lambda mod yet, but from what i understand, it is supposed to put the ECU into a default map, which generally runs the engine about 10% richer on fueling.
Definitely remove the sidestand switch. Mine failed miles from anywhere, and it took a while to diagnose
HTH
Nathan
HTH
Nathan
getting it back together.....
) to use the winter to get the job done. Still a little work to do, (rear shock is on route) put 20 ltrs of fuel in need to see if transfers seamlessly my guess is 280miles??
