Cigarette / USB charging
ILMV
Taunton, England
I wanted to be able to charge my iPhone and DSLR battery (and perhaps other stuff) on my bike, but didn't want a cigarette converter and cigarette to USB dangling all over the place.
Either way I've posted my solution over on my personal blog, it all fits inside a handle bar bag.
http://posterous.beneverard.co.uk/bike-usb-charging
You want shooting for connecting wires as badly as that :rob Apart from that it's a neat mod.
I know it's not the best wiring job, but it's secure, insulated etc... if I had a soldering iron and a load of heat shrink I'd have gone to town on it.
Either way, worked like a dream on my way home yesterday.
Neat solution (apart from the skanky connections) :thumb
I bought a bunch of waterproof bayonet connectors and something similar and have a flying lead which sits coiled up under the seat, behind the tank when unused. I poke it up and into my tankbag when required and attach whichever end I want to the bayonet (I made up a few 'ends' including USB and lighter socket etc).
<a href="https://picasaweb.google.com/lh/photo/ucT8zpofHPbdoqudsK5g70OOAeJkWHiivqDz0FeWdvU?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-aSpAc2jVxrc/TmfYf9ekZyI/AAAAAAAAFMk/Sq_IlnoL_O4/s640/IMG_6001.JPG" height="480" width="640" /></a>
I also ran permanent power to my little topbox using the bulkhead version of the connector:
<a href="https://picasaweb.google.com/lh/photo/LU6J8kbfQzYcc4IXHRgDYkOOAeJkWHiivqDz0FeWdvU?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-O53F8azt5vM/TmfYhFI64vI/AAAAAAAAFMo/ueYdnboOj88/s640/IMG_6002.JPG" height="480" width="640" /></a>
<a href="https://picasaweb.google.com/lh/photo/fRiygL8pN6WO0q5-CZEVj0OOAeJkWHiivqDz0FeWdvU?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-OT9LsSdynZc/TmfYiFz-d4I/AAAAAAAAFMs/Z9okYLIU7GQ/s640/IMG_6003.JPG" height="480" width="640" /></a>
All switched via an ignition switched relay so I don't end up leaving things connected and flatten my battery :blast
How did you reduce the voltage for usb?
I 're-purposed' a cheap USB lighter adapter ;) . It just had a little pcb with a switchmode powersupply and a USB socket in it - I fitted these into a little plastic housing with a short lead terminating in one of the bayonet connectors.
